Hello new here hope im doing this right. I have a 350 2 cycle with no spark was wandering how i might figure out how to fix it. Ihate to have to take it to a shop It is not worth 90 clams an hour
Unplug the single black wire from the cdi box then check for spark. By doing this you have eliminated any switches that might be bad. If still no spark then you have narrowed it down to the stator, cdi box and the coil. You can check the stator but will need a shop manual to get the proper specs. There is no way to test the coil or cdi.
Discussion Starter · #4 ·
where is the cdi box? I that the main box that all the wires go into just under the handle bars? If i unplug and still no spark where is the stator and can you test that or do you just repace it.
Discussion Starter · #6 ·
cdi box
just got home looking at the atv is the cdi box right above the coil ? part number ecu35pl cu2171 3d06. It has 2 sets o wire comin out of it one set with blk wire and bluewire .the blk wire connects into the pannal on side of handlebars and the blue wire into the coil. one set has three wires one wht ,one brownand wht,onered and black going to a plug. thanks for the info so far
