Wanting to know the full function of the reverse override switch. Handle bar tag says reverse and 4wd override. Does this allow the 4wd to operate in reverse at higher rpm or is this switch needed to disengage the 4wd. I see their are two wire & three wire switches learned this after purchasing a 2 wire, mine is a 3wire. Can the 2 wire be made to work. Thanks for any input Steve.
Welcome to the board!:med:
Have to push it to have full power and awd in reverse, can by-pass switch, id have to look in my notes at home to tell you how, might find it by doing a search.
Discussion Starter · #4 ·
thanks Russ, I would like to make it work properly. Now that I know how it works with the awd I guess I will have to find a three wire switch. thanks again. Steve.
