Been trying to find a procedure for oil pump adjustment and found the manual to be useless.
Anyone have a procedure for the adjustment? I have 2 marks on the oil pump cam and one on the pump housing.
Thanks.
Set your throttle cable and idle, then set the lines on the lever and the pump so they line up just as you take the slack out of the throttle before the idle RPM changes. If you look at the direction the lever moves, you want it to line up with the one that would be where Idle is. The other will be aprox full throttle.
