As some of you may know, I have been working on this machine for a few weeks now off and on. I had two issues with it. The first one was electrical. The second being overheating. Installed a new water pump impeller and a new thermostat. Tried to start it to purge the system and it will not hit a lick. There is spark at the sparkplug, so I have fire there. I tried starting fluid and I even shot some fuel down into the cylinder. Still it won't hit a lick. This machine was running before so I do not understand what could have happened. With the electrical I installed a new voltage regulator, new battery and a 10 Amp circuit breaker. The machine ran before I started in on the cooling system. I do not understand how or why it will not hit if its getting both fuel and fire? Anyone have an idea what this may be? If it were the valves I don't see how it would have ran okay prior to the cooling system work. I did remove the front rack, and forward body plastic. Along with that was the instrument cluster but it appears to be working okay. Could there be any sort of electrical connection somewhere that may not be hooked up? If so, why would I have spark but it won't hit?
Now here is one thing I have noticed about this machine. Sometimes while trying to start, it will kind of cough through the breather. In fact, when I sprayed starting fluid into boot, it backfired and ignited a little residual that was in the bottom of the breather box. But this is not a constant.
Compression check?
Valve adjustment check?
I am at a stand still once again.
Compression check?
