ok one is how do i find the date on the bike?2 can i safely bypass the oil injector ? 3 what clutches can i use to upgrade? 4 i drilled holes in the end of the tail pipe will that hurt anything? 5 i had about 600lbs including me i rode it about 2 miles seemed like it was short on power got to a stopping point it was hot as hell the inside of the pipe was glowing like it had a fire in it i got back home after it cooled i messed with it again still no power check air filter looked bad pulled it off and it came alive pulls the front wheels off the ground now so do you think from the bad filter is the reason it got hot?fan is running i bypassed it to a switch i turn on myself has plenty of coolant....also i mixed my own gas and put in the tank at a little more than 50 to one and its smokes pretty good plus the oil tank had a little in it so i can see why it would smoke lol...all in all the bike runs fair and was a good deal i think but i do want to get rid of the oil tank i need the room up there for a snorkle thanks for any help guys
