the bike wont crank or indicate neutral or reverse, where is the neutral indicator and how hard is it to change
check the kill switch, and it should crank with the brake lever pulled in. try the rope pull?
rope pull will work and crank the bike but the wife and daughter cant do this. does anyone know where the neutral indicator is located
