1 - 2 of 2 Posts
I hope someone can help. i have 2017 450 h.o. sportsman. getting fuel and spark but will not start. checked all fuses, replaced battery, went to start and it ran for a min, then couldn't start again. going to drain gas and start with fresh. any ideas would be helpful thanks...
Are you getting fire to the spark plug? And have you check the carb? I dont like doing it but you can spray a litt starting fluid on the air filter and see if it hits.
1 - 2 of 2 Posts
