hey guys, 04 sportsman 500 HO here
the 4wd works fine in reverse but not in any other gear. also the speedometer quit working not too long ago. could care less about the speedo working but thought it might have something to do with the 4wd maybe not working. any ideas? thanks!
Discussion Starter #2
well then... no one on here has a single clue? Think ill just replace the cage and Armature plate. thanks for the help....
I dont know much about the 04 but for somereason i think the two have something to do with each other. on the 02 mine would cut out and in and it ended up being a little brown wire that was loose. mine it didnt matter what gear though.
Does yours have the centralized hilliard, or fluid in the hubs? If is has the central hilliard, then it is an 04.5, and if the cluster is shot, you will not have AWD. Are you sure that you are not just getting full power in reverse?
