4X4 and lights wont work
5.6K views 5 replies 6 participants last post by  stefanj
96 magum no dash headlights tail lights or 4x4 working bike speed tops out at 25 mph,I have checked ciruit breakers and bulbs they are good i had to use a battery charger to get the bike going one day after that Installed a new battery. Also sometimes the kill switch won't work i fell like i am chasing a ground any suggestions. Bike starts runs and idle fine now i went through it
#5 ·
I know on my '02 Sportsman 500 6x6 I have had a problem with the light and the AWD not working 2x now. The first was a long time ago and found a broken wire (it was brown IIRC) and I cant recall if it was in the light pod or under the "hood". I had to follow the wire loom and actually had to search for it.
Seems that when the handle bars are turned it put stress right there. I just spliced the wires.
Second time it happened after several years I found my splice had slipped.
#6 ·
Yea chasing a bad wire is a nightmare. I just fixed a charging issue with mine. Best place to start is at the regulator. Make sure you got Voltage coming into the regulator (remember this is 3 phase AC- my machine makes about 36 volts at idle- almost 60 at 3/4 throttle). then just track each wire out of the regulator. My problem was back by the battery. The charging wire had corroded under the connector- took me 6 hours to finally discover it. Spliced a new wire (solder it, used a crimping splicer, taped it, and heat shrinked it, then gooped it up with di-electric grease- NO WAY that is going to happen again) Yea it was time consuming (and a Royal PITA) but the local shop wanted at least $300 for electrical diagnostics)
