New here, need a bit of advice from anyone who has replaced the front coil hub. I have a 2001 Scrambler 500 4x4 and the left side was destroyed when the previous owner fliped it. Got all of the bearings and seals on the way and everything looks ok (other than bearings and seals), but I am unsure if I need to replace the coil hub. I found a place to get it for $55, but it is not clear to me as to how to remove the old one. I do have a Hanes manual but it is limited in info on this subject. Any help would be greatly appreciated. I did do several searches prior to posting this thread as I did not find the info I am looking for. Thank you in advance!
