i have a 2000 scrambler
and with my 4x4 completely off driving on trails or road it doesnt matter my left wheel will engage... if i put it in neutral than back into drive... it stays engaged in 4x4 even with the switch off or on..... i drained and replaced the hub fluid and it still has the problem
i cant keep riding it like this or it will snap an A Arm or something
Discussion Starter #2
so i checked the hub fluid it was fine... took apart the hub assembly bearings are fine seals are fine spacer fine hillard clutch fine Armature plate fine no wear re-assembled and still the same problem.. i even disconnected the 4x4 switch wires from the struts
