1 - 2 of 2 Posts
I think my 4x4 on a 99 scrambler is not working. I have read a lot of post to test but never defined if the engine needs to be running when checking> what's the proper way? I have the hub off and turned the key on with the switch in AWD and placed a small alien wrench on the coil and it barely held, turn of the switch and did the same. what size wrench should it hold?
Both hubs do not engage. I disassembled both hubs to clean and refill with proper fluid. Clearance is good. Check for resistance at the plug under the hood, no short.
Discussion Starter #2
Answered my own question, the engine needs to be running. I have confirmed magnetism.
1 - 2 of 2 Posts
