I have a 2012 sportsman 500 HO when I ride and try to go top speed its like the motor just sputters and wont rev up and loses power. last time thus happend I just put a can of seafoam and it fixed it. this time seafoam aint working. any suggestions? plz help I filled up with premium gas and h ave been revvving it up trying to get the bad gas too pas threw. is this a good idea? what.can I do?
sounds like you need to do a thorough cleaning of the carb. Also check for air leaks around the airbox. You can do that by running it and spraying starter fluid and checking if the bike speeds up then you have an air leak.
anyone know a good carb cleaning tutorial?
Discussion Starter · #4 ·
can I rev it up in neutral? will that hurt it? I was trying to get the trash to pass threw. how do I clean the carb?
I would suggest getting a service manual and watching some YouTube videos or take it to a professional for cleaning.
It's not hard to do but there are a few really small pieces and springs that can easily get misplaced. I found the hardest part was getting the screws for the float bowl off bec they wanted to strip. I ended up using an impact driver.
This answer is more of a question, but something very similar happened to my buddy 2010 500HO a few days ago, and all it was ,his choke had backed out a little and gave the same symptoms you described. Have you checked your choke?
