1 - 14 of 14 Posts
Hey guys i just picked up a used 2004 polaris sportsman 500ho. It starts and runs great.Only issue is starter seems to stay engaged alittle too long and grinds.it has a brand new starter and relay. I check the bendex and it seems fine.It looks new,i just lubed it to make sure. I have seen other people complaining about this and some people say its normal. Is there any fix for this its driving me nuts. Thanks again
the spring in bendix may be weak....or bendix is dirty..dont want to over lube them..it collects metal bits from engaging an grime..just a few drops of 3-1 oil is all you need....NO wd-40 or grease..gums up....also make sure the thrust washer is on the end...
Thanks I ordered a new bendex.im hoping the spring is just weak. It can't hurt it cost me 21 bucks on amazon lol.
Welcome to the board!
Good..I hope it solves your problem....add a drop or 2 of 3-1 oil on it if its dry.....keep us informed how you made out...
Many of them do stay engaged for a second after starting but make sure the thrust washer is in place and check the bushing in the cover.
i have to replace the rope an handle on my recoil stater....I ordered parts..but since I will have it open I ordered new bushing an thrust washer....cheap insurance later on..I hope
Oh I didn't realize there was a buhing in the cover.is it metal or plastic.anyone have a part number.i better just replace it when I'm in there
its a metal bushing....can be a bitch to remove i was told...there is a video on youtube showing removal...I am going to see if advanced auto rents a bushing puller...its free actually..just leave a deposit....
the part for yours is 3083669 BUSHING, STARTER..its around 15.00....I figure if I am in there ..why not replace it...cant hurt...
Discussion Starter #12
Ok update. I installed the new bendex and replace the case bushing it was actually broken.It still grinds a little but it is definately better than before thanks.
On the 800 there is two bushings and I would think the 500 is the same way. One in the cover and one in the block. On the 800 the one in the block wears a lot more than the one in the cover
1 - 14 of 14 Posts
