The clutches all come specific part numbers based on the machine. It's hard to figure out which one you need sometimes. What year is your machine and I can get you a price on rebuilding it. Should be less than 2/3 the cost of a new one with a 2 way bearing installed to eliminate the EBS. All depends on the cost of the rebuild kit as there are a bunch of different versions out there. Most expensive rebuild kit is about $160, plus a bearing at $65ish, and $60 labor plus shipping. Some kits are as cheap as $60.
PN 1322682 is the complete primary from a 13 500 Non-EBS and will bolt right on. You will need to buy new spring and weights or swap yours over is still in good condition. But best to replace them.
