I have a 1999 500 that runs till it warms up and when the fan cuts on it starts to cut out and miss. If you turn the lights on it kills the engine.
batt is new and seems to be charging. Have checked connections grounds and wires for bad spots. If you have the plug out to ck spark it only fires intermitly if you crank with starter, if you pull the rope it is normal.
Any thoughts?
