I'm running 27 " swamplites what shim should I run in the primary for best throttle responce low end I have both thick and thin in right now the low end is ok the midrange is great any info would be great thanks
Can you add more shims to compensate? or would you just want a stronger spring?
Would have to go to a stiffer start spring. Any more shims and you risk it coming out of the pocket, and it could bind up the spring on full shiftout too. Going higher will make it very difficult to maneuver at slow speeds and make take offs very harsh.
Thanks for the info guys I didn't even think about break in time on a new belt that was the problem kit works great !
