1 - 20 of 63 Posts
My 570 didn't start yesterday. I pulled the plug and it looked fine. About a week ago when I started this machine it ran rough for the first 10-15 seconds and then was fine and then yesterday nothing I could not get to start.
I ended up taking it to the dealer (Ball Equipment in Richmond MI)
Let us know what you find out
Amen!
When mine did that was the shift sensor. Well not sure about the rough running my brother was using it when it wouldn't start.
Maybe a bad spark plug?
In for the result. Friend of mine haas a 570 RZR that is less than a year old, will very low Compression, with a no start condition. Seems the valves needed to be adjusted. Hope its something simple!
Hope its something simple. but not to simple... You did verify that the kill switch wasn't on, right?
Discussion Starter #13
Oh yes. I checked the kill switch it was in the run position I flipped it on and off a few times to check it and still no start . Made sure the brake was engaged before starting. I checked the air filter it was spotless.
Day 2: I have not yet heard back from the dealer.
Discussion Starter #15
I had been cranking on it for a while bore I took the video. On the gauge cluster it showed LO 10.8V. So it was a bit weak because it hasn't been run and I cranked it over quite a bit.
Discussion Starter #16
I checked all my fuses before loading it up on the trailer and none of them were burnt up.
probably just me being used to old school tech, but what were the numbers flashing up on the screen during the engine turning over? RPM?
Discussion Starter #19
Well Day 3. I have yet to hear from the dealer. If by the end of the week I dont hear any thing I will call them up. I am not sure if no news is good news in this case. I am still hoping for the best.
Banned
squeeky wheel gets the grease. if you're not bothering them then they may keep pushing it back. I'd call them.
1 - 20 of 63 Posts
