Not a problem shorty. But there is no difference between changing shocks and springs vs. changing just the springs. Many have the mistaken belief that shocks have something to do with ride height when its only the springs that have any effect on that. Shocks simply dampen or slow down the movement of the springs. Also, HD springs are relatively cheap while shocks are very expensive and make no difference in ride height.
Post a pic of what you have. Unless there's some sort of spacer I'm not aware of, you still have to remove the springs to add spacers. A set of spring compressors can be rented at most any auto parts store and it only takes a few minutes to change springs. I just put a set of HD springs on the front of a RZR a few days ago. Didn't even have to take them off the machine. Simply jacked it up, removed the wheels and top shock bolts. Rotated the shocks out and changed the springs and put it back together. The entre job took about 30 minutes.
