1 - 14 of 14 Posts
There is a terminal block above your radiator. I believe that's where you run your wires. Open the front rack, remove the torx screws in the middle section (in front of the pod), remove the round insulation circles the box, pop the middle section up and there it is.
+1. That's how I ran mine.....works perfect
You're welcome guys. It pays to tinker around.
Put a meter on it and see if you've got current. current it's a second positive, no current, it's a second negative/Ground.
1 - 14 of 14 Posts
