I'm new to this forum, so hi everyone. I've got a 2003 600 that won't go into awd. It hasn't bee run for several months. I'd figure I'd start with the switch, which doesn't light up when on. Is there a fuse for the awd switch?
I too have an '03 600 Sportsman that is having AWD issues, except mine wont engage in revers. A lot of people are saying to change the fluid which is what I am going to try next. Also check the wires going into the front case if you have power there it is not the switch.
Keep me posted with what you find maybe we can get this issue figured out!
Thanks rob. I will keep you posted. I ordered a manual just in case! Once some of this snow melts, I'll be able to get a better look at it.
