Need Help ,
I am looking at a clean Polaris 2003 600 twin. I drove it yesterday and at low speed when turning it is making clicking noises when you try to turn.
if it is a cv joint do you have to replace the whole axle assembly? How hard is it to change the cv joint and boots. does this take any special tools?
The left rear axle is throwing out grease right behind the wheel assembly.
The seller is asking $4250 with a Polaris 56" v-plow and frame. I thought I would offer him $3,000 as is and fix it myself.
2nd question: I was on a blacktop driveway and when I tried to turn it bucked around when I tried to turn left onto road. The 4 wheel drive switch was off. I turned the switch on & off and then backed the unit up but didn't seem to make any difference. Would that back axle problem make it hard to turn?
