1 - 2 of 2 Posts
The American Powersports service contract currently cost $649 for two years or $799 for 4 years with no deductible. We only offer the ultimate coverage to eliminate the deductible.
Ultimate Plan Coverage:
This coverage supplements the new Vehicle warranty from the manufacturer to the original owner of the Covered Vehicle. Included in this coverage is the replacement of covered components resulting from gradual wear and use when the wear exceeds the manufacturer’s specifications. Platinum coverage will cover necessary repairs to your vehicle’s mechanical and electrical except for items shown in a short exclusions list.
Engine: All internally lubricated parts, including: pistons, pins, rings; connecting rods and bearings; crankshaft and main bearings; camshaft, followers, and cam bearings; push rods, valves, retainers, springs, guides, seats, followers, and lifters; rocker arms, rocker shafts and bushings; internal reed valves (where fitted), transfer port valves, timing gears, timing chains, timing belt, timing chain/belt tensioners and retainers; eccentric shaft; oil pump. Oil pan; intake and exhaust manifolds; engine mounts and cushions; engine torque strut, timing cover; valve cover(s); harmonic balancer; flywheel (flexplate) and flywheel ring gear. Turbo/Supercharger (optional): Housing and all internal lubricated parts and waste gate are covered.
Transmission: (Automatic or Standard) All internally lubricated parts contained within the transmission case; all internal gears, bearings and chains; internal selector mechanism, shift linkage and shift lever, mounts.
Primary & Secondary Drive: All internally lubricated parts contained within the drive case except clutch and hub assemblies. All internal gears, bearings and drive chains, internal selector mechanism, transmission mount.
Final Drive (Shaft Driven Models): All internally lubricated parts contained within the driveshaft and final drive housing, driveshaft(s), ball and universal joints, driveshaft support and mounts.
Chain Case: All internal lubricated parts contained within the chain housing; jackshaft and jackshaft bearings, front axle and axle bearings.
Front/Rear Suspension: All internal lubricated parts contained within the front fork tubes including the front hub. Front and rear wheel bearings, swing arm bearings/bushings, upper and lower control arms, ball joints, king pins and bushings and spindles. Frame for weld failures only.
Steering: Upper and lower steering stem bearings and bushings, axle. Spindle, bearings and bushings. Steering knuckle (stem) and handle bar, adjustment nut(s), tie rod ends, adjusting sleeves and drag link.
Cooling: Water pump, fan motor, fan blade.
Brakes: Hand controls, disc brake calipers, master cylinder and reservoir, wheel cylinders, hydraulic hoses, lines and fittings, drum brake actuation cam and securing hardware, brake hub(s), brake backing plates. (Disc Brake Pads and Brake Shoes are not covered).
Electrical: Starter and solenoid alternator/ generator; voltage regulator; magneto, distributor; coil(s), rectifiers, stator, wiring harness; manually operated switches; electronic ignition module, electronic fuel injection control module and fuel injection sensors.
Taxes & Fluids: State and local taxes where applicable and fluids that are required to complete covered repairs.
Wear & Use: Included in this coverage is the replacement of covered components resulting from the gradual reduction in performance due to normal wear and use, when the wear exceeds the manufacturer’s specifications.
What makes this coverage different from majority of the other offerings?
Included in the coverage is the replacement of covered components resulting from the gradual reduction in performance due to normal wear and use, when the wear exceeds the manufacturer’s specifications.
Website link : UTV - American Powersports Service Contract
Discussion Starter #2
Steering racks, wheel bearings, ball joints, and several other commonly replaced parts are covered under the ultimate plan.
1 - 2 of 2 Posts
