Hi, anyone with a same model sportsman 6x6. A 2007. I just can't figure out what is out of line on my left front side.
The left front wheel is three quarters of an inch back the right side. My tire rubs on the fender when turning or bump. Stock tires.
Also the distance between the rim and strut is more then right side.
A-arm doesn't seem bent, strut doesn't seem bent, cannot see any frame damage.
I would like to compare some measurements with someone else tav so I can determine where the issue and cause are.
