Hi, my 6x6 doesn't sit level, it leans to the right. New front tires and all tires have same air pressure. Any ideas since its got two centre mono shocks for the rear?
first i would measure the shocks top bolt to bottom bolt and see if they are sagging on the side then check shock mounts to see if you have one bent, first i would go with a tape measure and start digging
thanks that did the job, right side strut is one inch lower then left side. any replacement brand would you recommend other then polaris genuine parts?
