New here and new to me 2002 700 needs crank, pistons and cylinder. I hear the 800 parts will fit but I am looking for better info if the factory parts will fit. If it comes to housing mods I can do them. If they don't then is there a place where I can find performance parts.
No, completely different. What i can do is give you a list of all possible donors for this.
Crankshaft:
2002 SPORTSMAN 700 A02CH68AA/AB/AC/CA/CB CRANKSHAFT and PISTON - A02CH68AA/AB/AC/CA/CB 1202222
2006 SPORTSMAN 700 A06MH68AA CRANKSHAFT and PISTON - A06MH68AA/AD/AF 2203067
2006 SPORTSMAN 700 EFI A06MH68AQ CRANKCASE and CRANKSHAFT - A06MH68AQ/AT/AX/AY/AZ 2203067
2007 SPORTSMAN 700 EFI A07MH68AX/AY/AZ ENGINE, CRANKCASE and CRANKSHAFT - A07MH68AX/AY/AZ 2203067
2007 SPORTSMAN 700 MV A07MH68MA/ME ENGINE, CRANKSHAFT and PISTON - A07MH68MA/ME 2203067
2007 RANGER 700 EFI 6X6 R07RF68AD/AF ENGINE, CRANKSHAFT - R07RF68AD/AF 2203067
2007 RANGER 4X4 700 EFI/LE R07RH68AD/AG/AH/AK/AL/AO/ ENGINE, CRANKSHAFT - R07RH68AD/AG/AH/AK/AL/AO/AP/AW 2203067
2008 RANGER 4X4 700 EFI/XP ALL OPTIONS R08RH68 ENGINE, CRANKSHAFT - R08RH68 ALL OPTIONS 2203067
2008 RANGER 4X4 700 EFI CREW R08WH68AG/AH/AK/AR ENGINE, CRANKSHAFT - R08WH68AG/AH/AK/AR 2203067
2008 RANGER 6X6 700 EFI R08RF68AD/AF/AZ ENGINE, CRANKSHAFT - R08RF68AD/AF/AZ 2203067
2008 SPORTSMAN X2 700 EFI A08TN68AX/AZ ENGINE, CRANKSHAFT and BALANCE SHAFT - A08TN68AX/AZ 2203067
2008 MVRS 700 4X4/IDF UPFIT/IDF WINCH UPFIT M08RH68AA/YH68MI/MW ENGINE, CRANKSHAFT - M08RH68AA/YH68MI/MW 2203067
2009 RANGER 4X4 700 EFI ALL OPTIONS R09HH68/HY68 ENGINE, CRANKSHAFT - R09HH68/HY68 ALL OPTIONS 2203067
2009 RANGER 6X6 700 EFI R09RF68AF/AR/AZ ENGINE, CRANKSHAFT - R09RF68AF/AR/AZ 2203067
2009 RANGER 4X4 700 EFI CREW R09WH68AC/AG/AH/AL/AR/AZ ENGINE, CRANKSHAFT - R09WH68AC/AG/AH/AL/AR/AZ 2203067
2010 MILITARY SPORTSMAN 700 M10MH68MA/MV ENGINE, CRANKSHAFT and PISTON - M10MH68MA/MV 2203067
2010 MVRS 700 4X4 M10YH68MA ENGINE, CRANKSHAFT - M10YH68MA 2203067
Pistons:
Year Model Name Model Number Assembly Name Part Number
2002 SPORTSMAN 700 A02CH68AA/AB/AC/CA/CB CRANKSHAFT and PISTON - A02CH68AA/AB/AC/CA/CB 2202107
2003 SPORTSMAN 700 A03CH68AA/AC/AF/AH/AL CRANKSHAFT and PISTON - A03CH68AA/AC/AF/AH/AL 2202107
2004 A04CH68AC SPORTSMAN 700 A04CH68AC/AF/AH/AJ/AT/AV CRANKSHAFT and PISTON - A04CH68AC/AF/AH/AJ/AT/AV 2202107
2004 A04CH68AU/CU SPORTSMAN 700 A04CH68AP/AQ/AU/CU PISTON and CYLINDER - A04CH68AP/AQ/AU/CU 2202107
2004 A04CH68AK SPORTSMAN 700 A04CH68AK/AL/AN/AO CRANKSHAFT and PISTON - A04CH68AK/AL/AN/AO 2202107
2004 SPORTSMAN 700 MILITARY A04CH68MB ENGINE, CRANKSHAFT and PISTON - A04CH68MB 2202107
2005 SPORTSMAN 700 EFI A05MH68AC PISTON and CYLINDER - A05MH68AC/AS/AT/AU/AW 2202107
2005 SPORTSMAN 700 A05MH68AK/AN/AD CRANKSHAFT and PISTON - A05MH68AK/AN/AD 2202107
2005 SPORTSMAN MV7 A05MH68AP CRANKSHAFT and PISTON - A05MH68AP 2202107
2005 SPORTSMAN MV 7 A05MH68MB ENGINE, CRANKSHAFT and PISTON - A05MH68MB 2202107
2005 RANGER XP R05RD68AA PISTON and CYLINDER - R05RD68AA/AB 2202107
2006 RANGER XP 4x4 700 R06RD68AA PISTON and CYLINDER - R06RD68AA/AB/AC/AD/AE/AF 2202107
2006 RANGER 6x6 EFI 700 R06RF68AA PISTON and CYLINDER - R06RF68AA 2202107
2006 SPORTSMAN 700 A06MH68AA CRANKSHAFT and PISTON - A06MH68AA/AD/AF 2202107
2006 SPORTSMAN 700 EFI A06MH68AQ PISTON and CYLINDER - A06MH68AQ/AT/AX/AY/AZ 2202107
2007 SPORTSMAN 700 EFI A07MH68AX/AY/AZ ENGINE, PISTON and CYLINDER - A07MH68AX/AY/AZ 2202107
2007 SPORTSMAN 700 MV A07MH68MA/ME ENGINE, CRANKSHAFT and PISTON - A07MH68MA/ME 2202107
2007 RANGER 700 EFI 6X6 R07RF68AD/AF ENGINE, PISTON and CYLINDER - R07RF68AD/AF 2202107
2007 RANGER 4X4 700 EFI/LE R07RH68AD/AG/AH/AK/AL/AO/ ENGINE, PISTON and CYLINDER - R07RH68AD/AG/AH/AK/AL/AO/AP/AW 2202107
2008 RANGER 4X4 700 EFI/XP ALL OPTIONS R08RH68 ENGINE, PISTON and CYLINDER - R08RH68 ALL OPTIONS 2202107
2008 RANGER 4X4 700 EFI CREW R08WH68AG/AH/AK/AR ENGINE, PISTON and CYLINDER - R08WH68AG/AH/AK/AR 2202107
2008 RANGER 6X6 700 EFI R08RF68AD/AF/AZ ENGINE, PISTON and CYLINDER - R08RF68AD/AF/AZ 2202107
2008 SPORTSMAN X2 700 EFI A08TN68AX/AZ ENGINE, PISTON and CYLINDER - A08TN68AX/AZ 2202107
2008 MVRS 700 4X4/IDF UPFIT/IDF WINCH UPFIT M08RH68AA/YH68MI/MW ENGINE, PISTON and CYLINDER - M08RH68AA/YH68MI/MW 2202107
2009 RANGER 6X6 700 EFI R09RF68AF/AR/AZ ENGINE, PISTON and CYLINDER - R09RF68AF/AR/AZ 2202107
2009 RANGER 4X4 700 EFI CREW R09WH68AC/AG/AH/AL/AR/AZ ENGINE, PISTON and CYLINDER - R09WH68AC/AG/AH/AL/AR/AZ 2202107
2009 RANGER 4X4 700 EFI ALL OPTIONS R09HH68/HY68 ENGINE, PISTON and CYLINDER - R09HH68/HY68 ALL OPTIONS 2202107
2010 MVRS 700 4X4 M10YH68MA ENGINE, PISTON and CYLINDER - M10YH68MA 2202107
2010 MILITARY SPORTSMAN 700 M10MH68MA/MV ENGINE, CRANKSHAFT and PISTON - M10MH68MA/MV 2202107
Cylinder:
2002 SPORTSMAN 700 A02CH68AA/AB/AC/CA/CB CYLINDER and CYLINDER HEAD - A02CH68AA/AB/AC/CA/CB 2202158
2003 SPORTSMAN 700 A03CH68AA/AC/AF/AH/AL CYLINDER and CYLINDER HEAD - A03CH68AA/AC/AF/AH/AL 2202158
2003 FRONTIER CLASSIC BUILT BEFORE 1/01/02 S03ND7DS CYLINDER and CYLINDER HEAD - S03ND7DS 2202158
2004 SPORTSMAN 700 MILITARY A04CH68MB ENGINE, CYLINDER and CYLINDER HEAD - A04CH68MB 2202158
2004 A04CH68AC SPORTSMAN 700 A04CH68AC/AF/AH/AJ/AT/AV CYLINDER and CYLINDER HEAD - A04CH68AC/AF/AH/AJ/AT/AV 2202158
2004 A04CH68AK SPORTSMAN 700 A04CH68AK/AL/AN/AO CYLINDER and CYLINDER HEAD - A04CH68AK/AL/AN/AO 2202158
