I have a 2002 Polaris 700 Sportsman 4x4 made before 05/2002 and I need somewhere to buy some axles for this ATV..I have 2" of lift and 28" tires..My axles only have 3 1/2" on the spliced end to go into the hub..newer model has 4 1/2" from splined end or could I swap out the bearing carrier for the later model to allow for the longer axles? .I can provide the vin # if needed.This is a picture of the hub end of my axles..Mine is in the middle and the 2 outter are for an 02 as well.
I'm guessing the later models have different hubs. I would be looking to see what else is different between them and be considering the more common upgrade and use the longer axles. Might just be hubs or could also be struts and a-arms.
I can't find any difference in part numbers except for the axles themselves. I checked an 02 model and an 04 unless I missed something it's all the same and should fit.
