1 - 2 of 2 Posts
I am looking for a 3-4 inch suspension lift for my 2004.5 700 sportsman and was wondering where I could find one also who are the best companies to buy from.i installed 27x9 mega mayhems on and they rubbed.then I put 2 inch wheel spacers on and that made it worse so im gonna go ahead and lift it.i would settle with a 2 inch but would like more.any input would be greatly appreciated.thanks.
WELCOME!! My biggest worry about any lift is the stress it puts on your axles because of the increased angles you will be running them at.
YOU WILL have axle issues.
IF you must lift it, be sure you budget in the expense of new stronger axles that are designed to run at steeper angles you ride will then have.
1 - 2 of 2 Posts
