Hi Iam working on a 2002 Polaris 700 Twin it has sputtering problems so I cleaned out carb put on a foam air filter and a bigger better gas filter. Well it rides golod for short distances then will sputter super bad then run good but sputtering is happening evrytime you hit gas. I see alot of gas inside carb when give gas . Anyone know what I should try? Also how many turns does the fuel regulator screw need be out? Its up under front fender where gas lines run into. Thanks
