The Neutral, Temp, and EPS lights in the pod will flash on for a split second. The duration is so short, it's hard to see.
I noticed this a couple weeks ago . I thought I was seeing things but I caught it on video tonight. The flashes are just over a minute apart.
Should I assume this is NOT normal and have the dealer check it out? It's still under warranty.
There is no key in the ignition. There are added accessories. But none of the OEM wires were altered except the 2 orange/white ones the factory. I've had about all the plastics off and haven't seen any signs of foul play.
Damn tapatalk says I can't upload any more images this month...
I'll email the photo to someone if they want to add it here.
