1 - 14 of 14 Posts
I have a recently purchased 2013 850. It has about 450 miles. The transmission seems to "slip" at low rpms when I try to take off. It pulls and jerks a little bit before engaging.
It pulls and jerks around 1800-2200rpm before fully engaging and going. It is more dramatic if it is starting on an uphill climb.
Any ideas?
I know it sounds like the belt case has water in it. I tried to drain that. Not a drop came out. And we have not rode it through anything other than mud puddles, no deep water.
It is still under warranty, but I would like to know what is going on if anyone can help.
Does it sounds like something is damaged?
I will try to post some videos.
Thank you!
Have you took a look at the belt?
Sent from my GT-P5113 using Tapatalk 2
Replace the belt and it will disappear.
Sent from my SCH-I545 using Tapatalk 4 Beta
Was the video taken with the machine in "low" or "high" range?
Most of the time its from running it in high gear at speeds under 12mph. after a while it starts causing problems were is hard to shift gears.
thanks mscldawg. You seem to know quite a bit. Is there anything else you can tell me?
is the belt a pain to change ?
should I take it to dealer since it is still under warranty?
thanks
The video was taken with it in High Gear.
That would be the problem.........belt needs replaced. Low speeds in high range will ruin a belt is a very short time. Dealer, most likely, will not replace it as it is considered a wear item and is usually worn due to rider abuse.
Discussion Starter #11
How tough is it to change the belt on these models?
I know it wasn't too bad back when the engine wasn't rotated like it is on the EFIs.
Its a pretty easy job. Keep the old belt for a backup but before you take it off mark with a arrow what direction its turning so you know how it goes back. I mark up . Also be sure too torque the 2 frame bolts back too I think 60lbs but dont quote me on that. Tire, frame bolts. Cvt cover and your there. There are axnumber of youtube videos too help.
Discussion Starter #13
mscldawg,
I see you have a 2012 850. Do you have a PDF service manual for it?
I have emailed, and PMed PolarisTech1 here on the boards about getting a 2013 service manual but not have heard back.
I do but it's an 09 manual, I don't know if there is a 12 or not. I looked at one point and couldn't locate one and the changes are so small I didn't worry about it. I can email it,just shoot me a personal message with your email info.
1 - 14 of 14 Posts
