1 - 20 of 124 Posts
My 850 xp "hesatates" when i push the throttle from idle/low rpm's. I've had this issue since new, and the dealer have no idea to solve this problem. Thanks from Gunnar, Sweden
do you mean hesitates like the engine bogs down or sputters?.. if that's the case, something's wrong.. If its more about the fact that it takes a few extra rpms to build up before movement, than its the way the xp is clutched and is normal..
Have them check the TPS for the proper setting if it's an engine hesitation. If it a get up and go hesitation, that's the stock soft clutching. A clutch kit will cure that and I can ship to Sweden too! Done a bunch of sled stuff for a guy on HCS a few times over the years.
Welcome to the board!:med:
Install a hotter plug. The stock will hesitate, especially in colder climates
Sent from my iPhone using Tapatalk - now Free
Might be time to take it to a different dealer.
It's not a clutching problem, it's the Engine, first "splatter" then it revs up.
Mines the same way! 2 dealers around me say it's normal! I thought it was odd too
2013 850ho
Ok! What do you mean "odd"?
Odd as in I don't think it should be that way like the dealer said it was normal. But it's been that way since new so I've just been riding it. Mine has even ALMOST died a few times it was so bad.
2013 850ho
Discussion Starter · #13 ·
2013 850ho
2013 850ho
I see. Mine HAS died a few times ex. when shifting gears and pull the throttle immideately up to about 40-50%(half throttle). Sorry for my bad English.
2013 850ho
That's when mine died also was stop change gears get on throttle and just down right stubble down to nothing. But it's not done it that bad in a while now it's just alittle stubble then revs like normal
2013 850ho
09 850 spark plugs
Polaris ATV Forum - View Single Post - 09 850 spark plugs
Thank you! I'll try to replace the plugs, even if I have a little hard to believe that hotter sparkplugs can make this "big" change. But i really hope you'r right with this easy soloution!:)
The 850 models run a bit rich on the bottom end. They are also easy to foul a plug if you start it and only let it sun for a few secs,......like moving it across the garage
Absolutely they make a big difference. I fouled two sets before I went to the NKG Iridium's and have not had an issue at all. As faawrenchbndr said they run rich and starting and stopping them with out warming them up is very hard on the stock plugs. They carbon foul and then stop working.
Discussion Starter · #19 ·
I can fully understand that Change of sparkplugs solves idle and starting problems, but throttle response?
Sent from my LT25i using Tapatalk
Discussion Starter · #20 ·
My 850 have been running for about 160 hours with the factory mounted plugs, with no other issues than bad throttle response at low rpm.
1 - 20 of 124 Posts
