shop manual tells you to remove the rear fender and it is easyer to get the cover off if you do. also remove the shifter bar makes it easyer to get the cvt tube out of the way.
Has anyone need to change the belt on their XP? If so how many miles did you have on your machine before you needed to change it ?
