this year I picked up an 2013 850 xp . for the first 300 miles it ran great now it runs rough when cold and has a bog when you first go full throttle pretty bad from a standing start. not sure if anyone has any ideas .
If its not throwig any codes, try chenging out the plugs. I heard the machine runs rich during break in and fouls out the plugs. Then it tuns like crap when cold, hard stafting, etc.
you can run alittle seafoam in with the gas it helps keep the injectors clean
x2 on checking/changing the plugs.
Do a compression test. Has the symptoms of low compression.
