This machine is a sweet ride and plenty of power....however already have a check engine light flashing with a stuck throttle code 520194-7. Having owned several other Polaris machines ...with thousands of miles on them, not impressed with reliability at this point.
Mine was a TPS. Replaced, has iridium's in and no issues for a while now.
Mine got the code also. Found it was just a Zip tie too tight on the handlebars just down from the throttle.
Discussion Starter · #4 · (Edited)
Its still in the shop, seems to be others with this issue as well....some cases worse than others. Mine at first was intermittent then eventually got to the point wont even idle to warm up...or if it does idles very fast then starts to cut out. I did the handle bar throttle adjustment according to the 2-3mm specs...problem still persist. Many post on this issue with 2009 850's...would have thought by now would have it resolved.
Still no word form the dealer on my repairs....
