1 - 10 of 10 Posts
i recently put a new battery on and before the new battery it would crank right up and now it turns over but won't fire up. i pulled the spark plugs and they are black i cleaned them and they are getting spark to them and the fuel pump is pumping fuel idk why it won't fire up
Welcome to the board!
If the plugs were black, change them.
Make sure the new battery is fully charged or better yet try to jump start it.
Discussion Starter · #7 ·
its fully charged and never bogs down when i go to start it but still won't fire off only sits there and turns over constantly the spark plugs are brand new also
you probably already checked the obvious BUT Kill switch, gas turned off or empty tank, double check those,,, maybe you knocked a wire lose, can you hear the fuel pump working ?
Discussion Starter · #10 ·
Figured it out it was my power commander programmer burnt up and wasn't allowing fuel in the injectors but once I hooked up my oem injector plugs it works anyone else have this issue
1 - 10 of 10 Posts
