Hi! Is there any available soulotion for the speedometer when using tracks?
Yes, that's exactly what i want. I know that can-am has an electric module witch is plug & play, that corrects both the odo and speedometer while using tracks.What part of the speedometer are you concerned with, speedometer or odometer? Maybe both? I have tatou tracks on my 550 and never even gave it a thought. I also have a GP mounted and can get the actual speed from that, if I want.
Or are you looking for a solution to correct the factory speedometer/odometer? Don't think there is anything, since it is all electronic. Maybe a way to program the ECU?
with which drive Wheel? there is 4 diffrentIf I remember correctly Camoplast told me it was 2 to 1 ratio.
I have 16-17 teeth Wheels.with which drive Wheel? there is 4 diffrentIf I remember correctly Camoplast told me it was 2 to 1 ratio.
15, 16. 17, 18 theet Wheels![]()
