Hey guys I've tried searching and haven't found much info... I keep getting a 102 code for the map sensor, from what I've read it's most likely a loose connection. So my question is where exactly is it located and how do I get access to it?
If you take the left side plastic off, you will see it on the intake plenum. It's a real PITA to get to.
I had the 102 code with the "out of range" error. It has gone away but I do have a replacement TMAP sensor if it comes back again. Major disassembly to get at it though.
Mark
Checking the manual, it's just forward of the MAG (front) throttle body. PM me your email and I can send you the section in the manual that shows location and replacement procedure.
Mark
