took it to the dealer and had the carb rebuilt . that was warm weather now that winter is here . noway will it start without either. after starting its all good. never used to be that way. all the threads wasnt matching this problem. please help. also the trans grinds to go into gear. i read somewhere am i supposed to use my brake peadle to put into gear . its always done this is there an adjustment for this other than adjusting the idle. already tried that helps a little. thank you.
Welcome to the board!
It sounds like the choke needs to be adjusted. I had the same quad and it never needed starting fluid. Very seldom needed full choke unless it was very cold.
