21 - 40 of 47 Posts
Now I'm lost even worse - the cylinder is filled with liquid and there is no holes from the combustion chamber to the outside of the cylinder. Those fitted with compression releases were always on the head. HELP ME - I'm need to know what it is you are talking about
aknawful, don't most of the sleds also use a power valve in the exhaust in combination with the decomp holes in the cylinder? I didn't see anything like that on the 350L??
Most sleds now do use power valves. I believe the original 2001 xc 800 liberty twin did not have powervalves but did have decompression holes.
When the big twins (800/900) came out they were bears to start when cold.
An old trick was to put the choke to full before shutting them down for the night. The theory was the extra fuel would wash the cylinders down of two stroke oil. Alowing it to turn over easier on the cold mornings.
Yeah, I did a quick scan of some of the threads and apparently those holes allowed some of the compression to leak off for cranking etc. The guys blocking them off were talking about it adding some bottom end power but that the difference was unnoticeable on the top end. I'd never heard of this before but it makes sense to let some pressure off when the piston moving slow as in starting but making no real difference at high RPM.
Discussion starter · #31 ·
Got it going finally. Runs well I would say, so I'm happy. It fires right up, but still is a little iffy on the idle part. Probably needs a carb cleaning. However, when I put it in reverse, it will die unless I'm holding the override button. Is this normal?
Discussion starter · #37 ·
Thank you, my throttle cable frayed and the throttle got stuck wide open. Really fun.... Haha luckily it's icy here and it just spun out. The spring must have been bent and it wore on the side of the carb. The barn is fine, just the spring is bad.
I won't say normal since it is not supposed to do that. It should run in reverse, but sputter and pop if you try to go too fast. Unless the over ride button is pushed. It is not uncommon however for the machine to die when shifted to reverse unless the over ride button is pushed. Both my 325 machines do the same thing. I added a speedo kit to one which replaced the reverse limiter and for a while it didn't die every time I shifted to reverse. Worked like it is supposed to for a while, now it comes and goes. I just get into the habit of holding the button when I shift to reverse.
Does anyone know the deal as why it does it?
Disconnect the black ground wire from the Rev limiter (#33) and see if it does it. IIRC it ties into the cdi to cut power in reverse unless you hold the button. When it goes bad it'll just kill the engine rather than intermittently cut ignition. If that keeps it from quitting, you need a limiter. Sounds to me like that may be the problem.
21 - 40 of 47 Posts
