I recently cleaned the carb and wil start but not idle also i use mixed gas 50:1 in my outboard and was hoping to bypass the oil and oil pump and use mixed gas in my atv.Any advice on these two issues would be greatly appreciated
Had a problem like that similar to mine. Endend up being a hole in my fuel line. Check that and check to see if the boot that comes from the carb to the intake has a crack or is loose.
