i have a 2x4 94' 350trail boss that recently was running and i heard a clanking noise in the engine and then it turned off. the engine cranked over once, then stopped.if i move the clutch to the right it will turn and then if i push the start button it will start then stop at the same place it was.
the engine isnt seized
i was told the crank could be gone
or something could have fallen into the carb and got stuck under the piston so it cant move downward.
please help
Look between the motor and trans. There is probably going to be a hole there. Not good It ran to low of crankcase oil.
More than likley the rod is broke and came thru the block.
