1 - 12 of 12 Posts
94 sportsman 400 . Was running good one day . Then just died ..
Coolant reservoir empty .. spark plug looked like muddy water on it and pulled the head ..same thing on the inside . Changed the head gasket and spark plug , refilled coolant . Still No start and spark plug looks like mud again....
What do I check next , what could it be ....
Sounds to me as though the water pump seal failed a long time ago and the coolant is mixed with the counter balance gear oil and now the LH crank seal has failed and the oil/coolant mixture is getting into the crankcase. Check the counter balance oil and see what it looks like.
ok , where is that located? yes possibly could have happened awhile ago the previous owner said this atv was sitting for a year but he got it started . i drove it no issues for 3 months ...then this happened...
You got the recoil cover off - before you pull it all apart and find out there is nothing wrong deeper inside, what does the oil look like in the counter balance gear chamber?
There is where the coolant is going - past the water pump seal into the counterbalance drive gear housing and ultimately into the crankcase - engine needs a complete rebuild - new main bearings and seals, water pump kit and might as well re-ring it and perhaps even bore it out with a new piston kit.
Discussion Starter #12
So where do I begin haha . Any other posts on a rebuild . I have a general idea What needs to be fixed based upon what you said is wrong
1 - 12 of 12 Posts
