Bike will not turn off with key or engine kill switch? Lights turn off with key but not engine. any suggestions would be appreciated. Solenoid checks good and wiring from switches are good
I also have that same problem so what I have done so far is check all of my wires and they were fine I changed out the key switch thinking that was the problem now I'm going to change the Cdi box hoping that is it and if it's not then I'll be taking it to the shop have you fixed yours at all?
400 ign
yes after tracing down many wires the problem resulted from a bad ground wire. the wire was in a dumb place under the front rack and was corroded cleaned it up and no more problems
