1 - 2 of 2 Posts
Sorry for the stupid questions right off as a new member, but I just got an old 95 300 2x4 that has sat for 4 years without running. I cleaned the carb and found some lines that were dry rotted and cracked. Does anyone have a diagram of what hose goes where? Also, where is the tranny oil drain and fill. Since it has sat so long, I want to change out all the fluids. I did manage to get it to drive in forward and reverse after adjusting the idle on the carb. The machine will only pull start. The battery is dead after sitting so long. The previous owner said the start button does not work. Any suggestions aside from cleaning the conectors and checking the wires once I get a battery? The key does not matter if it is on or off... Sorry for all the questions, I hope I will be able to help someone else after working on this thing.
On my 300 the two tubes coming out are just over flows. the one with the one way valve is the overflow for the floats (bottom of carb)
1 - 2 of 2 Posts
