Is your AWD light coming on when the button is pushed in? Please give as much detail about your problem. When did it stop working? What was you doing when it stopped working, etc?
Sorry to drag this from the grave but I dont wanna start a new thread for the same problem.
I have a 95 Scrambler 400. When I put it in 4wd the right front tire will not engage. Only the left turns. When I got the 4wheeler it would be all 4 tires turning. The cv axle isn't broke. I looked at the hub and everything appears to be fine. i refilled it with correct fluid. Im at a loss any help would be appreciated.
there should be a wire running down either strut down to the hubs. the wire still intact? locks these magnetic roller bearings in your hub.
