95 700 Sportsman intermittent pod failure "FIXED"
Hello all, just joined the forum and have a problem I hope I can find help with. I have a 93 700 Twin Sportsman, I have been using it for plowing snow in Iowa (Lot's of snow this year). Recently I have noticed that the speedo in the pod seems to intermittently go blank and reset while I am using the ATV. The engine is running just fine, but when the speedo goes through this reset the AWD no longer is engaged. Once the speedo has reset and I can see the readings all is working again.
When I am in neutral the speedo stays on, I can rev the engine and all seems good, but when I put in forward or reverse then I start seeing the speedo display go blank, it will stay like that then I see it come back and reset (Like when I first turn on the engine).
I have opened the pod and removed and reconnected the connectors, but it still keeps doing it. I feel it may be a bad ground or something loose because it happen mostly when I am plowing and the ATV is being jolted. Any help would be very helpful.
