1995 Polaris Magnum 425 4x4
Bought this wheeler several years ago and it's mainly sat since i've owned it...i've maybe run it 1-2hrs tops primarily just starting it every once in awhile when sitting in my garage.
The summer of 2018 i bought a pull start assembly for it since the guts of the old one were missing. I installed it but never used it.
Fast forward to last weekend. Son ran the wheeler for a hour or two and then it sat overnight. Next morning it was nippy out and the battery drained overnight. So we went to use the pull start. First issue was the new pull handle was melted to the exhaust. Once we pried that off, we gave it a few pulls but no luck. So we hooked it up to the charger. After a bit of time we went to fire it up with the electric starter and when we did it sounded like the pull start unit imploded! Shut everything off and brought it home.
And boy did it ever, see pictures below.
The entire pull start housing is junk (has at least 4 holes in the case and entire rope assembly fell apart when i took it off).
Question 1: I can't tell if the starter drive bendix is bad or not. It seems to operate fine, but the piece on the opposite end of the gear end doesn't look like the new one in this photo. Is mine ok or not?
Question 2: Also, appears to be a broken bushing on the motor side where the bendix goes...anyone have a part number and how-to to replace that?
Question 3: I'm finding little pieces of what appeared to be a spring at one point...was that something that belonged to the pull start or would that have come from someplace else?
Question 4: What would be the best way to clean out all the shavings in my housings....ideally without taking the flywheel off?
