hey there everyone... i am new to the forum and joined because i recently
purchased a magnum 425 4x4 on a good deal... it was needing a new carb and
i installed one and after figuring out the fuel pump it came back to life...
it really runs solid but i can only shift into L N and R when trying to shift into H it makes a really horrible grinding noise... i know the shifter is not engaging into H but works great at L??? any ideas? i know you can adjust the arm but how??
thanks for all the help...
laterz
MrCrazyNutz
:beerchug:
Welcome to the board!
There should be a lock nut on both the shifter side and tranny side, take those nuts loose and do some slow adjustments. I have seen alot of shifters that the detent wears out. Very easy fix, and cheap. You may want to take a look at that too. Let me know if that works.
