Magnum front drive
When I engage the AWD on a 95 Magnum 425, the left front wheel does not drive. This worked fine until last night when I parked it, today it doesn't. What could cause this?
Would the cold temp. (12 Degrees F) cause this? I assume this is an electrical system that engages the front hub?
Could someone point me in the correct direction. :shrug:
Discussion Starter #2
I found the culprit, The wire that runs down the strut, which feeds the magnetic coil, was broken. Someone had spliced a speaker wire in between the original wire for a quick fix, only it didn't last. Glad I found this and fixed it, now, it works fine.
